Documentation update history
The following updates have been made to the Blue Prism product help:
Date updated
Summary of update
Related help page(s)
30 October 2023
New Region mode topic added, and Object Studio topics reordered with spy modes moved to a new dedicated spy mode section of the help.
Region mode
30 October 2023
Audit actions and events guide updated with two new codes.
27 October 2023
Updated scripted installation information.
Silent installation
18 October 2023
Updated browser extension information.
Edge browser extension
Added to ASCR configuration information regarding WCF port number.
ASCR server configuration
06 October 2023
Added note to Loop Start stage information.
Loop Start stage
27 September 2023
Updated Mainframe page.
Mainframe integration
15 September 2023
Additional information about the /dbwait command has been added.
Command line options
Advanced installation and configuration
01 September 2023
Added details of load balancer compatibility to ASCR guide.
Application Server Controlled Resources (ASCR)
31 August 2023
New! Release notes published for Blue Prism 7.2.1.
Release notes 7.2.1
24 August 2023
Updated 7.2 release notes to include VBO section.
Blue Prism 7.2: April 2023
21 August 2023
Added guide on Global Send Keys and Global Send Key Events.
15 August 2023
Added information about restarting the Blue Prism server when updating a server configuration.
Blue Prism server
10 August 2023
Updated Authentication Server information:
  • Added note about client ID being case sensitive from Hub 4.7.
  • Added step 6 in Enable Authentication Server login in you Blue Prism environment section.
Authentication Server configuration
02 August 2023
Added clarification of connections in Desktop client installation.
Install and connect the Desktop client
25 July 2023
Added Attribute Tuning Best Practices Guide for Web Applications
Attribute tuning best practices for web applications
24 July 2023
Added clarification on optional components for version 7.
Installation
17 July 2023
Added note on required permissions for runtime resources
Troubleshooting browser integration
Java automation
Enterprise preparation
Blue Prism runtime resource
Resource PC modes
13 July 2023
Added information for environment variables
Processes/Objects – Environment Variables
23 June 2023
Added information on disabling automatic updates for browser extensions
Disable browser extension automatic updates
9 June 2023
Added reference to Digital Exchange asset on Blue Prism API Postman configuration
API configuration
8 June 2023
Updated Audit Actions and Events Guide
8 June 2023
Added information on resource pool controllers
Resource pools
19 May 2023
Updated the Login Agent guide.
Login Agent
17 May 2023
Updated information on Web API.
Updated information on process and object comparison.
Updated information on Blue Prism API configuration
Web APIs
Process or business object comparison wizard
API configuration
12 May 2023
Updated information on resource pools and grouping resources.
Resource pools and Resource management
11 May 2023
New! Help published for Desktop 1.1.
Desktop 1.1 documentation
28 April 2023
Blue Prism 7.0 release notes updated with BP-2503 correction.
27 April 2023
New! Help published for Blue Prism 7.2.
Blue Prism 7.2 documentation
