Business objects – management
The Active Objects panel shows a list of all available objects, displayed in their object groups.
Business object retirement
To retire an object that you do not want to be used – either permanently or temporarily, double-click the object, or drag it into the Retired Objects panel. Retired objects cannot be called from another process or business object and are not available for editing, viewing, exporting etc from the Object Studio Menu.
To unretire an object, drag it into a folder in the Active Objects panel.
