Contained databases
Blue Prism supports the use of contained databases, hosted on Microsoft SQL Server. To use a contained database, it is necessary to manually create the database and apply the Blue Prism CreateScript.sql.
The CreateScript.sql script can be obtained in the following ways:
- Via a request to Blue Prism Customer Support
Generated using AutomateC. To generate the script, use the following command:
AutomateC.exe /getdbscript > CreateScript.sql
Generated using the Blue Prism client: Click Generate Script at the bottom of the Create a new database or Upgrade the database screens.
Create contained databases
- Create a SQL Server database using Microsoft SQL Server Management Studio or by using an alternative method if required.
- Run the script to create the required Blue Prism tables, views, and other required objects in the database.
- Configure a connection to the database as described in Create and configure a Blue Prism SQL database.
