Processes – Management
The Active Processes panel displays a list of all available processes, displayed in their process groups.
Process retirement
To retire a process that you do not want to be used, either permanently or temporarily, double-click the process, or drag it into the Retired Processes panel. Retired processes can not be run from another process as a subprocess and are not available for editing, viewing, or exporting from the Process Studio menu.
To unretire a process, drag it into a folder in the Active Processes panel.
