Single sign-on settings in a single-authentication environment
Domain
The domain where the Blue Prism Security Groups will reside needs to be specified. The fully qualified domain name (e.g. "global.MyDomain.local") must be entered.
Verify connection
The Verify Domain button can be used to validate that Blue Prism can connect to a domain using the name provided from the current device.
Administrators group
When configuring single sign-on for Blue Prism it is necessary to select an Active Directory security group whose members will be granted access to all areas of Blue Prism. The configuration of single sign-on for Blue Prism should be undertaken as a user who belongs to this security group.
Once the database is created and configured for single sign-on, a Blue Prism administrator should sign into Blue Prism and configure the required Blue Prism user roles. Once these have been defined, each role should be associated with an Active Directory security group via the Security - User Roles screen.
Troubleshooting
If you experience issues, see Single sign-on troubleshooting.
