Advanced installation
Select which optional components to install:
  • Outlook Automation – Installs the DLL required to use the Blue Prism Outlook Email VBO. Requires 952KB on your hard drive.
  • Google Sheets Automation – Installs the APIs required to use the Blue Prism Google Sheets VBO. Requires 408KB on your hard drive.
  • Chrome Browser Extension – Applies the registry setting that instructs Chrome to add the Blue Prism browser extension, required if interacting with Chrome from Blue Prism. Requires 1KB on your hard drive.
  • The Chrome browser extension is also used with Chromium-based versions of Microsoft Edge. However, the extension must be installed manually for Edge.
  • Firefox Browser Extension – Applies the registry setting that instructs Firefox to add the Blue Prism browser extension. Requires 196KB on your hard drive.
