Blue Prism Trial and Blue Prism Learning Edition
We offer two alternative versions of our SS&C | Blue Prism® Enterprise product to help you become familiar with Blue Prism and, if you are looking for a more structured approach, start teaching yourself how to use Blue Prism with support from our training labs and Blue Prism University.
Blue Prism TrialFind out how easy it is to automate your organization’s internal processes and discover how Blue Prism can improve efficiency and productivity throughout your business. What's included...
Learning EditionBegin your Robotic Process Automation (RPA) journey with Learning Edition, and discover new opportunities by becoming a certified Blue Prism developer through the Blue Prism University. What's included...
The license differentiates the two versions. Both versions install the same software and come with a single digital worker so you can run your automated processes against target applications. To support you, we provide free access to our product documentation, training materials, and the Blue Prism community – click here for details.
* The Blue Prism Learning Edition contains all the development capabilities of the Enterprise Edition, however the Learning Edition restricts the product's functionality in the following areas:
- Blue Prism application server – The service and executable will still be installed, and the option to select Blue Prism Server as the connection type is available in the Connection Configuration dialog, however the license prevents the Blue Prism Server service from starting.
- Scheduler – The Scheduler is disabled. This prevents the ability to autonomously coordinate the Blue Prism digital workers.
Users cannot upgrade from the Learning Edition to an Enterprise Edition directly, but must uninstall the Learning Edition and subsequently install the Enterprise Edition.
Before you start...
Ensure your device meets the minimum requirements
For details on the minimum requirements, see Standalone installation hardware requirements.
