Blue Prism Hub platform (including Interact, ALM and other plugins)
The Blue Prism Hub platform includes the following plugins:
- Blue Prism® Interact – available in all versions.
Interact is an additional product that requires an additional license key to operate. - Blue Prism® Automation Lifecycle Management (ALM) – available from version 4.1.
The Automation Lifecycle Management plugin is an optional service that requires an additional license key to operate. - Control Room – included from version 4.3.
The Control Room plugin is an optional service that is freely available to use. The Control Room plugin is compatible with Blue Prism 7.0 or later and requires the Blue Prism API. - Blue Prism® Decision – available from version 4.5.
The Decision plugin is an optional service that requires an additional license key to operate.
The tiles above are for the latest version of the Blue Prism Hub platform. Earlier versions are also available, click here for more information.
Earlier versions of documentation
Our documentation systems are updated for each new release and a new version is created for every major and minor release. To select the documentation for a different release, click the Select version drop-down and select the required version.
Earlier releases to download
Earlier releases of the Blue Prism Hub platform can be downloaded from the Blue Prism Portal. On the latest download page for the Blue Prism Hub platform, you will find a link to the previous release. Click the link to access the installers for the earlier release.
