Capture
Capture combines task extraction and computer vision to produce a Process Definition Document. You can reduce overall process development time further thanks to its ability to create a SS&C Blue Prism process release file based on the initial process recording. This file contains everything a developer needs to build the automation, accelerating time to value for the business.
The tiles above are for the latest version of Capture. Earlier versions are also available, click here for more information.
Earlier versions of documentation
Our documentation systems are updated for each new release and a new version is created for every major and minor release. To select the documentation for a different release, click the Select version drop-down and select the required version.
Earlier releases to download
Earlier releases of Capture can be downloaded from the Blue Prism Portal. On the latest download page for Capture, you will find a link to the previous release. Click the link to access the installers for the earlier release.
