Standard deployment
The standard deployment pattern is a simple architecture, which deploys a single copy of each component, and co-located where possible, according to their logical role in the system.
Deploying multiple instances of any component is an option either for resiliency and/or performance reasons, and in such scenarios reference should be made to the high availability deployment pattern for additional requirements, such as load balancers.
Standard deployment component breakdown
Standard deployment network architecture
The following diagram depicts a standard deployment network architecture that includes SS&C Blue Prism Enterprise, Blue Prism Capture, Blue Prism Decipher IDP, Blue Prism Decision, Blue Prism Hub, Blue Prism Interact, and Blue Prism Authentication Server deployments. Click here to view the accompanying legend.
Network architecture diagram legend
