Hub 3.0 – February 2020
This release note is for the 3.0 release of Blue Prism Cloud Hub (Hub) delivered in a standalone configuration.
Important notices
Ensure you have reviewed the upgrade notices for this release.
Release notes
Enhancements
The following new features and enhancements are introduced in this version of [product].
Area |
Description of change |
IMS |
Implemented new Identity Management Server (IMS). |
New IMS ‘Login’ screen + new flow. |
New IMS ‘Forget password’ screen + new flow. |
New IMS Interact registration screen + new flow. |
New session control mechanism. |
SMTP |
New encryption control. |
New SMTP authentication control. |
You can now test your email configuration by sending a test email to email of the user you're logged in as. |
Database |
IADA URL included in ‘Database’ settings modal. |
User, Roles and Registration Approvals |
User Settings have been changed to ‘Users, Roles and Registration Approvals’ on the ‘Settings’ toggle to accommodate Interact registrations. |
Registration approval number is included within settings toggle, this will let the administrator know how many Interact users need to be reviewed. |
‘User, Roles and Registration Approvals’ option will be highlighted in red if the administrator has to review registered Interact users. |
Setup status column within the user table has been added to assist administrators in understanding if a user has been setup correctly. |
New Interact registration table and tab. |
New Interact registration approval/deny workflow. |
Customization |
You can customize the look of IMS (including Login, Forget Password and Interact Registration pages). |
You can customize the look of Interact. |
Audit |
Audit option included within the Settings toggle. |
New Audit table. |
The following categories will be tracked for audit reasons - User Management, SMTP Management, Role Management, Live Access, Authentication Settings, Digital Workers. |
.NET Core |
Migrated Hub to .NET Core 2.2. |
Core |
IMS and Hub supports the following languages English, French German, Japanese, Russian, Spanish, Portuguese (Brazilian) and Chinese. |
Fixes and minor improvements
The following fixes and minor improvements are introduced with this version of [product].
Area |
SMTP |
Improved ‘Email’ settings modal |
Database |
Improved ‘Add New’ database modal |
LDAP |
Authentication settings option included within the ‘Settings’ toggle |
New ‘Authentication’ settings table |
Improved ‘LDAP’ configuration page |
You can test to see if ‘LDAP’ has been implemented correctly |
New flow to import users from LDAP |
User Settings have been changed to ‘Users, Roles and Registration Approvals’ on the ‘Settings’ toggle to accommodate Interact registrations |
Adding ‘New user’ modal to include Hub/Interact, Privileges/Roles, language and themes |
New ‘Edit user’ modal to include Hub/Interact, Privileges/Roles and theme |
New ‘Roles’ table and tab |
‘Create Role’ modal redesign, you now have the option to create a Hub or Interact role |
New ‘Edit role’ modal |
You can now re-use the same email address as a user who has retired |
My Profile |
A new profile page that includes the users Username, First Name, Last Name, Email Address, Language, Avatar and the ability to edit Password |
Core |
Footer inline image no longer get cut off |
