Blue Prism Cloud EER4.2 – March 2020
Interact |
2.7 |
The release requires the Interact to be this version. |
This release note document is for the Evolution Edition Release 4.2 of the Blue Prism Cloud Platform.
Release notes
Enhancements
There are none for this release.
Fixes and minor improvements
The following fixes and minor improvements are introduced with this version of Blue Prism Cloud.
Description |
Any changes you made in an organization’s Active Directory will now be reflected in Interact when an LDAP sync has been initiated. This means that if a user is removed from the Active Directory that user will also be removed from Interact following an LDAP sync. |
The restriction on the number of registered domain users on an LDAP connection has been lifted. Previously, only the first 1000 registered domain users in this scenario would be synchronized with Interact. |
All changes to the paragraph field now successfully save. Previously any amendments to this field did not save. |
Tabs in the Form Builder can now be edited once created. |
Administrators can now re-submit forms on behalf of user if IADA is down. Previously Administrators would have to manually replicate forms and submit them. |
