Blue Prism Cloud EER4.1 – February 2020
Hub |
1.22.2 |
The release requires Hub to be this version. |
IADA Email |
4.0 |
The release requires IADA Email to be this version |
Blue Prism |
6.4.3a |
The release is compatible with the specified version of Blue Prism version and above. |
This release note document is for the Evolution Edition Release 4.1 of the Blue Prism Cloud Platform.
Important notices
Ensure you have reviewed the upgrade notices for this release.
Release notes
Enhancements
The following new features and enhancements are introduced in this version of Blue Prism Cloud.
Description |
Several changes have been made to the Blue Prism Cloud Digital Workforce architecture to support new functionality delivered in the EER4.1 release and to improve efficiencies within the platform. These are for new platform deployments only and include:
A second standby instance of the IADA Orchestrator is deployed for this release. This is for multiple purposes:
The Web Server virtual machine has been updated in the EER4.1 release for all new and existing platforms. To enhance the architecture further a Production and Development instance of Interact will be deployed. The Development instance will have its own database associated with it to ensure that developments can be properly promoted. This will allow isolation of Interact process forms between production and development environments. |
IADA Email now provides support for 64-bit and 32-bit installations of:
Profile and Store control and management means mails from any email profile created in the operating system and any stores created in profiles can now be accessed and managed. Stores are mail accounts inside an Outlook profile. |
Fixes and minor improvements
There are none for this release.
Plugin updates
A number of plugins are provided in a Blue Prism Cloud release – new and/or updated plugins are listed below.
Updated plugins
As part of this release all existing plugins have been updated to support a new form structure that has been introduced. New plugins also support this new structure.
New plugins
Plugin |
Description |
Live Access |
Live Access allows operators to access their digital workforce from within Hub. Users can browse to Hub and from there launch Live Access to the required digital worker. There are two modes available:
Upload |
The Upload Plugin function is Blue Prism Cloud’s start to open Hub to allow users to build and install their own plugins. |
Upgrade notices
IADA Email
A number of DLLs must be added to the Blue Prism directory
The following DLLs must be installed at the root level of the Blue Prism Automate directory in your install location. This is particularly important when running against earlier versions of Outlook, e.g. Outlook 2010.
- IADAEmail.dll
- VBIDEApi.dll
- OutlookApi.dll
- NetOffice.dll
- OfficeApi.dll
- Stdole.dll
Run RegistryUpdater when Outlook has been installed
The RegistryUpdater.exe must be run once Outlook is installed. This will add the necessary keys in the registry to allow IADA Email to access Outlook API’s without being blocked by a security prompt. Once Outlook has been installed, simply run the RegistryUpdater.reg to add the necessary registry keys to allow IADA Email to interact with Microsoft Outlook without security warnings.
To ensure IADA Email has access and permission, in Microsoft Outlook navigate to File > Options > Trust Center > Trust Center Settings > Programmatic Access, select Never warn me about suspicious activity and click OK.
An updated IADA Email User Guidedetails how to get the best from this functionality.
