Page stage
The page reference properties dialog has a number of fields to fill in.
- Enter a name – The name that you enter identifies the stage and will be displayed on the process diagram.
- Enter a description – The additional description field allows a lengthier narrative to be entered.
- Choose a page – From the drop down list select the page to be executed.
- Edit Inputs – Edit the inputs of the page.
- Edit Outputs – Edit the outputs of the page.
Input Parameters to the process are specified here. Correspondingly, if the start stage resides on a subpage, the parameters set relate to that page; any stage which references that subpage will have the opportunity to pass values via the page reference stage to the page itself. To add a parameter simply click the grid below the "name" column to add a name to the parameter. Then choose a datatype below the "data type" column. Finally select a data item to store the input parameter to by dragging a data item from the data explorer and dropping it into the value column.
