Code stage
The code stage adds the power and flexibility of a professional programming language to the visual convenience of the Blue Prism flow charting tool. This provides the expert user with freedom to perform data manipulations that would otherwise be cumbersome from within Blue Prism, or indeed to interface with the API of a piece of software from within Blue Prism. In particular a code stage is often useful for interfacing with a COM object in a Microsoft Windows environment.
The code stage has a close relationship with the global code declared as part of the business object. Member variables and methods declared in the global code section are accessible from the code stage, but not vice versa.
Properties Form
The properties form consists of three tabs: inputs, outputs and code. The inputs and outputs declared are in the form of Blue Prism values and data items, as for an Action Stage. These values are "translated" by Blue Prism to their corresponding Visual Basic .NET equivalents for use in the final tab. Please note that since not all Blue Prism data types have a corresponding equivalent in the .NET framework, only a restricted set of Blue Prism data types is permitted.
Based on the inputs and outputs supplied, a method header is automatically generated, declaring your inputs and outputs for you. You may not edit this header except by editing the list of inputs and outputs in the first two tabs.
Inputs are passed by value to your method. This means that a copy of the value-typed data in Blue Prism will be passed to your method. Modifying this data will not affect the value of the data in Blue Prism. In contrast, outputs are passed by reference. This means that instead of a copy of the value being passed to your method, a pointer to the value is passed instead. This means that any modifications you make to the variable in your method will instantly be propagated into the business object, modifying your chosen data item.
Click the Check Code button, in the Code tab, to validate your code. This uses the Process Validation tool and can be used to detect potential errors.
