Blue Prism API
The following information is applicable to all versions of the Blue Prism 7.0 API.
- Blue Prism API installation guide – Install and configure the Blue Prism API.
- Blue Prism agreements – Access the agreements that form the basis of your contractual relationship Blue Prism when using the Blue Prism API.
Blue Prism API version 7.0.1
The following Blue Prism API reference and Blue Prism API user permissions for the Control Room plugin apply to version 7.0.1 of the Blue Prism API only:
- Blue Prism 7.0.1 API Reference – View, test, and download the Blue Prism 7.0.1 API reference.
- Blue Prism API user permissions for the Control Room plugin – User permissions required to achieve specific responses in the Blue Prism Hub Control Room plugin via the Blue Prism API.
The following Blue Prism API reference and Blue Prism API user permissions for the Control Room plugin apply to version 7.0 of the Blue Prism API only:
- Blue Prism 7.0 API Reference – View, test, and download the Blue Prism 7.0 API reference.
