Recover stage
Recover stage
The Recover stage is where execution will jump to when an exception occurs. For an overview of exceptions, see Exceptions.
- Name – The name that you enter identifies the recover stage, it will be displayed on the process diagram.
- Description – The additional description field allows a lengthier narrative to be entered.
Maximum attempts
To set a maximum number of attempts for this stage, select Limit the number of times this recover is attempted and set the Maximum Attempts value.
When configured in a business object and the limit is reached, the process will move on to the calling process or business action page.
When configured in a process and the limit is reached, an error will display if debugging. If the process is running as a session, the process will terminate.
