Process stage
The process properties dialog has a number of fields to fill in.
- Enter a name – The name that you enter identifies the process and it will be displayed on the process diagram.
- Enter a description – The additional description field allows a lengthier narrative to be entered.
- Choose a process – From the drop down list select a Blue Prism process to execute.
- Edit Inputs – Edit the inputs of the process by choosing a datatype from the dropdown list. Enter an expression or drag a data item from the data explorer into the value field.
- Edit Outputs – Edit the outputs of the process, by dragging a data item from the data explorer into the value field.
