End stage
The end stage properties dialog has a number of fields to allow you to define what happens at the end of the process.
- Enter a name – The name that you enter identifies the end stage, it will be displayed on the process diagram.
- Enter a description – The additional description field allows a lengthier narrative to be entered.
- Enter outputs – Outputs of the process are specified here. These relate to parameters that are passed out of the process when the process is run. To add a parameter simply click the grid below the name column to add a name to the parameter. choose a datatype below the data type column. Finally select a data item to store the input parameter in by dragging a data item from the data explorer and dropping it into the value column.
