Blue Prism 6.10 to 6.10.5 Third-Party Licenses and Acknowledgments
Blue Prism® includes a number of third-party classes which are referenced by the platform and this topic records the items that are included and their respective licenses. Open source components will only be adopted on a permissive license basis and there are no copyleft licenses as part of our third-party arrangements.
There are a number of sections in this topic that differentiate the components that are used in the main product, trial version, and separate optional components that cater for particular scenarios.
This document contains the following sections:
Main product
Version |
2.2.5.0 |
Context |
OCR pre-processing |
Purpose |
Used to scale and monochrome a screen-capture |
Location |
Object Studio OCR Read Stage action |
Copyright |
Copyright © AForge.NET, 2006-2013 |
License |
Version |
4.8.1 |
Context |
Dependency injection |
Purpose |
Provides programmatic dependency injection within the code structure |
Location |
N/A |
Copyright |
Copyright © 2014 Autofac Project |
License |
Version |
1.3.0 |
Context |
Integration of Autofac and NLog |
Purpose |
Provides logging infrastructure to components managed via AutoFac container |
Location |
Throughout the Blue Prism application |
Copyright |
Copyright © 2013 Ziya SARIKAYA |
License |
Version |
4.2.1.0 |
Context |
State machine library |
Purpose |
Used with MassTransit to maintain the state of long running processes that are controlled via messaging |
Location |
Message-based architecture which is currently not yet active |
Copyright |
Multiple contributors (https://github.com/MassTransit/Automatonymous) |
License |
Version |
73.1.13 |
Context |
Required for the use of Blue Prism with external identity providers |
Purpose |
Used by Blue Prism to provide an embedded web browser that can be used to sign in to the system via external identity providers |
Location |
Opened from the Blue Prism login screen |
Copyright |
© 2008-2015 The CefSharp Authors |
License |
Version |
73.1.13 |
Context |
Purpose |
Location |
Copyright |
License |
Version |
73.1.130 |
Context |
Purpose |
Location |
Copyright |
© The CefSharp Authors |
License |
Version |
73.1.130 |
Context |
Purpose |
Location |
Copyright |
License |
Version |
N/A |
Context |
A calendar and date picker with culture awareness |
Purpose |
Allows calendars to reflect the public holidays of the selected locale |
Location |
Public Holidays selector in System - Calendar settings and throughout Blue Prism where calendars are available |
Copyright |
See license |
License |
Version |
Both 3.3.0.0 |
Context |
Feature toggles |
Purpose |
Allows features to be turned on and off |
Location |
Throughout the application wherever there is a requirement to disable a feature without removing code. |
Copyright |
Copyright © Jason Roberts |
License |
Version |
3.0.1.0 |
Context |
Pipes and filters library for Task Parallel library |
Purpose |
Used as part of the MassTransit library |
Location |
Copyright |
Copyright © 2007-2019 Chris Patterson |
License |
Version |
1.11.24 |
Context |
HTML parser |
Purpose |
Parse the HTML being returned by the plugin so that we can then use the application navigator with Chrome, Firefox and Edge. |
Location |
Application navigator |
Copyright |
License |
Version |
IdentityModel 3.10.10.0 and IdentityModel.OidcClient 2.9.0.0 |
Context |
OpenID Connect (OIDC) client library |
Purpose |
Allows Blue Prism to communicate with an OIDC Authentication Server |
Location |
Used in Web APIs when requests are made using OAuth 2.0 authentication. |
Copyright |
Copyright © 2018, Dominick Baier and Brock Allen |
License |
Version |
3.0.1 |
Context |
Used for the representation of dates in available locales |
Purpose |
Implementation of the ICU Message Format in .NET |
Location |
Where localized dates are presented in Blue Prism |
Copyright |
Copyright © 2014 Jeff Hansen |
License |
Version |
Both 0.9.7 |
Context |
GUI controls/rendering |
Purpose |
Displays statistical information in a graphical format – used for rendering chart tiles on Blue Prism dashboard GUI |
Location |
Used in the Tile Library (preview mode) and on dashboards |
Copyright |
Copyright © 2016 Alberto Rodriguez & LiveCharts contributors |
License |
Version |
6.2.4.0 |
Context |
Messaging framework |
Purpose |
Allows message-based communications between different components |
Location |
Not actively used – enables potential future feature set |
Copyright |
License |
Version |
7.0.2 |
Context |
MassTransit integration with RabbitMQ |
Purpose |
Allows RabbitMQ to be used as the message bus when using MassTransit |
Location |
Copyright |
Copyright © 2007-2020 Chris Patterson |
License |
Dual-licensed under the Apache License, Version 2.0 and the Mozilla Public License v1.1. |
Version |
2.0 |
Context |
.NET compiler platform |
Purpose |
Provides the c# and vb.net compilers for Blue Prism code stages |
Location |
Object and process execution |
Copyright |
Copyright © .NET Foundation and Contributors |
License |
Version |
5.2.2.50423 |
Context |
Web API |
Purpose |
Creation of access tokens |
Location |
API connections that use the Oauth 2.0 (JWT Bearer Token) authentication type |
Copyright |
Copyright © Microsoft Corporation All rights reserved. |
License |
Version |
4.0.0.0 |
Context |
Web API |
Purpose |
Used to decode a PKCS8 private Key |
Location |
Copyright |
Copyright © 2003-2004 Various Authors |
License |
Version |
3.0.2.0 |
Context |
Unique Id Generator |
Purpose |
Used within the message-based architecture to generate unique database efficient ids for messages. |
Location |
Copyright |
License |
Version |
Newtonsoft.Json.Bson 1.0.1.20722 and Newtonsoft.Json 11.0.1.21818 |
Context |
String Manipulation |
Purpose |
Facilitates JSON data conversion – commonly in association with REST web services |
Location |
Optional Visual Business Object (JSON VBO) |
Copyright |
Copyright © 2007 James Newton-King |
License |
Version |
4.5.11.8645 |
Context |
Structured logging for .NET platforms |
Purpose |
Provides a flexible and configurable infrastructure for recording application log information for diagnostic purposes |
Location |
Used throughout the Blue Prism application |
Copyright |
Copyright © 2004-2018 Jaroslaw Kowalski ([email protected]), Kim Christensen, Julian Verdurmen |
License |
Version |
1.6.2.1321 |
Context |
NLog Provider for Microsoft.Extensions.Logging |
Purpose |
Allows NLog to be used for logging in .NET Standard libraries and .NET Core applications |
Location |
Copyright |
Copyright © 2016, NLog All rights reserved. |
License |
Version |
2.4.4.0 |
Context |
Date and time formats for .NET. |
Purpose |
Used in libraries for handling dates and times |
Location |
Copyright |
Multiple contributors |
License |
Version |
N/A |
Context |
GUI controls/rendering. |
Purpose |
Custom drop downs, combo boxes and tree-views in GUI forms. Fragments of Novell code have been modified and are used in Blue Prism developed custom combo box and tree controls. |
Location |
Process and Object studio editing forms |
Copyright |
Copyright © 2004-2006 Novell |
License |
Version |
7.2.0.1422 |
Context |
Prism is a framework for building loosely coupled, maintainable, and testable Windows applications |
Purpose |
Provides an event mechanism that enables communications between loosely coupled components in the application |
Location |
Communication between UI components in the application |
Copyright |
Copyright © 2017 Brian Lagunas |
License |
Version |
5.1.2.0 |
Context |
Decipher IDP |
Purpose |
Facilitate communications between the Decipher IDP Server and Blue Prism robots |
Location |
Connections that use RabbitMQ to communicate with Decipher IDP |
Copyright |
Copyright © 2007-2020 VMware, Inc. or its affiliates. |
License |
Version |
Scintilla.NET 2.6.0.0 and SciLexer 3.2.3 |
Context |
GUI Controls/Rendering |
Purpose |
Syntax highlighting and code editing within GUI controls |
Location |
Object Studio - Code Stage properties form |
Copyright |
Copyright © 2002-2006 by Garrett Serack <[email protected]> Copyright ©1998-2006 by Neil Hodgson <[email protected] |
License |
Version |
1.0.2.0 |
Context |
Functionality wrapper: operating system |
Purpose |
Provides functionality to configure bindings between a https port and a certificate |
Location |
Blue Prism Server configuration utility |
Copyright |
Copyright © 2015 Serghei Gorodetki |
License |
Version |
4.2.0 |
Context |
Managing asynchronous tasks |
Purpose |
A library for composing asynchronous and event-based application logic |
Location |
N/A |
Copyright |
Copyright © .NET Foundation and Contributors. |
License |
Version |
4.0.0. |
Context |
OCR Engine |
Purpose |
OCR engine for recognizing on-screen characters |
Location |
License |
Originally developed at Hewlett Packard Laboratories Bristol and at Hewlett Packard Co, Greeley Colorado, and licensed under the Apache License, Version 2.0. Also uses Leptonica, Copyright 2001 Leptonica, with a 2-Clause BSD license. |
Version |
N/A |
Context |
GUI control/rendering |
Purpose |
Provides functionality to provide tree list views with combined data columns |
Location |
Studio and Control Room to present hierarchical data views of objects, processes, resources, queues etc. |
Copyright |
Copyright © 2002-2003, Thomas Caudal |
License |
Version |
N/A – 4 July 2007 Code Sample |
Context |
Purpose |
Provides a SplitButton control, i.e. allows users to select the action of a GUI button using a drop-down list |
Location |
Wherever a split button is used outside of a toolstrip, i.e. Application Modeller ("Regions", "Identify"), Region Editor's Font property Editor ("New"), Session Log Search ("Fields") |
Copyright |
wyDay Copyright © 2011, wyDay |
License |
External components
Optionally used components available for use with Blue Prism.
Authentication Gateway
Authentication Gateway is a web application that runs in Internet Information Services (IIS), which extends the user authentication capabilities of the Blue Prism platform by providing connectivity to external identity providers using OpenID Connect.
Version |
5.1.4.0 |
Context |
Authentication Gateway application core |
Purpose |
Autofac is an IoC container for Microsoft .NET. It manages the dependencies between classes so that applications stay easy to change as they grow in size and complexity. |
Location |
Copyright |
Copyright © 2015 Autofac Contributors |
License |
Version |
6.0.0.0 |
Context |
Purpose |
Autofac implementation of the interfaces in Microsoft.Extensions.DependencyInjection.Abstractions, the .NET Framework dependency injection abstraction. |
Location |
Copyright |
License |
Version |
9.0.0.0 |
Context |
Purpose |
A convention-based object-object mapper |
Location |
Copyright |
Copyright © Jimmy Bogard |
License |
Version |
See the version numbers for the components listed below. |
Context |
Azure service integration |
Location |
Copyright |
© Microsoft Corporation. All rights reserved. |
License |
Components |
This license covers the use of the following component variants:
Version |
2.2.0.0 |
Context |
Application bootstrapping |
Purpose |
Code Generation tool for ASP.NET Core. Contains the dotnet-aspnet-codegenerator command used for generating controllers and views. |
Location |
Copyright |
License |
Version |
4.2.0.0 |
Context |
Identity services |
Purpose |
OpenID Connect & OAuth 2.0 client library |
Location |
Authentication Gateway provider authentication |
Copyright |
License |
Version |
3.1.3.0 for all variants |
Context |
Identity services |
Location |
Copyright |
License |
Components |
Version |
Context |
Identity services/Authentication Gateway application core |
Location |
Copyright |
License |
Components |
Version |
Context |
Location |
Copyright |
License |
Components |
Version |
4.700.19.56404 for all variants |
Context |
Location |
Copyright |
License |
Components |
Version |
2.8.0.62830 for all variants |
Context |
Application performance metrics |
Location |
Application development |
Copyright |
License |
Components |
Version |
1.0.19269.1 |
Context |
Application data database persistence |
Purpose |
Provides the data provider for SQL Server. These classes provide access to versions of SQL Server and encapsulate database-specific protocols, including tabular data stream (TDS) |
Location |
Copyright |
License |
Version |
3.100.320.12804 for all variants |
Context |
Location |
Copyright |
License |
Components |
Version |
3.100.320.12802 for all variants |
Context |
Location |
Copyright |
License |
Components |
Version |
Context |
Identity services |
Location |
Copyright |
License |
Components |
Version |
Context |
Identity services |
Location |
Copyright |
License |
Components |
Version |
Context |
Copyright |
License |
Components |
Version |
2.2.0.0 for all variants |
Context |
Location |
Copyright |
License |
Components |
Version |
4.700.19.56404 |
Context |
Purpose |
Provides support for managing access and audit control lists for Microsoft.Win32.RegistryKey. |
Location |
Copyright |
License |
Version |
12.0.2.23222 |
Context |
Data structures |
Purpose |
Json.NET is a popular high-performance JSON framework for .NET |
Location |
Copyright |
Copyright © 2008 James Newton-King |
License |
Version |
Context |
Application logging |
Location |
Copyright |
Copyright © 2004-2020 NLog Project https://nlog-project.org/ |
License |
Components |
Version |
4.7.0.5148 |
Context |
Purpose |
NuGet's understanding of target frameworks. |
Location |
Copyright |
License |
Version |
4.700.19.56404 |
Context |
Purpose |
Provides types that can be used to model the structure of a source code document and to output source code for that model in a supported language. |
Location |
Copyright |
License |
Version |
Context |
Location |
Copyright |
License |
Components |
Version |
4.6.24705.1 for all variants |
Context |
Location |
Copyright |
License |
Components |
Version |
4.700.19.56404 |
Context |
Purpose |
Provides types that support using configuration files. |
Location |
Copyright |
License |
Version |
Context |
Location |
Copyright |
License |
Components |
Version |
4.700.19.56404 |
Context |
Purpose |
Provides the System.Diagnostics.PerformanceCounter class, which allows access to Windows performance counters. |
Location |
Copyright |
License |
Version |
Context |
Location |
Copyright |
License |
Components |
Version |
5.5.0.60624 |
Context |
JWT certificates |
Purpose |
Includes types that provide support for creating, serializing and validating JSON Web Tokens. |
Location |
Copyright |
License |
Version |
4.1.1.36654 |
Context |
Purpose |
Interactive Extensions Async Library used to express queries over asynchronous enumerable sequences. |
Location |
Copyright |
License |
Version |
Context |
Location |
Copyright |
License |
Components |
Version |
4.1.1.36654 |
Context |
Purpose |
Provides support for Language-Integrated Query (LINQ) over IAsyncEnumerable<T> sequences. |
Location |
Copyright |
License |
Version |
4.700.19.56404 |
Context |
Purpose |
Provides access to a rich set of management information and management events about the system, devices, and applications instrumented to the Windows Management Instrumentation (WMI) infrastructure. |
Location |
Copyright |
License |
Version |
4.700.19.56502 |
Context |
Purpose |
Windows Communication Foundation (WCF) ServiceModel elements. |
Location |
Copyright |
License |
Version |
4.700.19.56404 |
Context |
Purpose |
Provides classes that enable customized reflection contexts. |
Location |
Copyright |
License |
Version |
4.700.19.56404 |
Context |
Purpose |
Provides classes to use caching facilities. |
Location |
Copyright |
License |
Version |
4.700.19.56404 |
Context |
Purpose |
Provides access to Windows Data Protection API |
Location |
Copyright |
License |
Version |
Context |
Location |
Copyright |
License |
Components |
Version |
4.700.19.56404 |
Context |
Purpose |
Provides the System.ServiceProcess.ServiceContainer class, which allows you to connect to a running or stopped service, manipulate it, or get information about it. |
Location |
Copyright |
License |
Version |
4.700.19.56404 |
Context |
Purpose |
Provides support for managing access and audit control lists for synchronization primitives. |
Location |
Copyright |
License |
SAML 2.0 Extension
The SAML 2.0 extension is an optional component available to use with the Authentication Gateway component.
Version |
1.8.5.50 |
Context |
Identity services |
Purpose |
BouncyCastle.Crypto is a cryptography API |
Location |
Copyright |
Copyright © 2000-2020 The Legion of the Bouncy Castle Inc. (http://www.bouncycastle.org) |
License |
Adaptation of the MIT License X11 |
Version |
1.11.15.0 |
Context |
Identity services |
Purpose |
This is an agile HTML parser that builds a read/write DOM and supports plain XPATH or XSLT |
Location |
Copyright |
Copyright © ZZZ Projects Inc. |
License |
Version |
2.8.1.16671 |
Context |
Identity services |
Purpose |
SAML2P support for IdentityServer 4, allowing SAML 2.0 Identity Provider and Service Provider functionality. |
Location |
Copyright |
Copyright © 2019 Rock Solid Knowledge Ltd. All rights reserved. |
License |
Commercial license to redistribute |
Version |
3.100.19.56601 |
Context |
Identity services |
Purpose |
ASP.NET Core middleware that enables an application to support the OpenID Connect authentication workflow. |
Location |
Copyright |
License |
Version |
5.5.0.60624 for all variants |
Context |
Identity services |
Location |
Copyright |
License |
Components |
Version |
12.0.2.23222 |
Context |
Data structures |
Purpose |
Location |
Copyright |
License |
Version |
5.5.0.60624 |
Context |
JWT certificates |
Purpose |
Location |
Copyright |
License |
Version |
4.6.24705.1 |
Context |
Purpose |
Provides extension methods that add System.Xml.XPath support to the System.Xml.XmlDocument package. |
Location |
Copyright |
License |
Browser Extension (Chrome)
The browser extension is available to allow Blue Prism to natively automate web browsers such as Chrome. The extension is optionally installed (or available from the browsers store). A capability to automate Internet Explorer is provided within Blue Prism that does not require this extension.
Version |
Crypto-js Version 3.1.9 |
Context |
Communication Encryption |
Purpose |
Provides encryption of the communication that takes place between Blue Prism and the Browser Extension. |
Location |
Only required where this optional component is installed. |
Copyright |
Copyright © 2009-2013 Jeff Mott Copyright (c) 2013-2016 Evan Vosberg |
License |
Version |
1.0.3 |
Context |
Communication capability |
Purpose |
Provides communication with the browser extension. |
Location |
Copyright |
Copyright © 2010-2018 sta.blockhead |
License |
Data Gateways
Data Gateways provides a centralized method of pushing data out of Blue Prism for use in external systems for monitoring and reporting, long-term data storage, and to feed machine learning models. Data Gateways is based on the existing Logstash capability (detailed below) which is a separate source base and a separate component from the Blue Prism product.
Version |
6.6 |
Context |
Data transport and processing |
Purpose |
Used in Data Gateways processing to send session log data to outputs |
Location |
Data Gateways engine |
Copyright |
Copyright © 2013-2018 by Elasticsearch BV. |
License |
Version |
4.2 |
Context |
Provides SQL server database connectivity from Java applications |
Purpose |
Used by Logstash to connect to SQL server databases |
Location |
Copyright |
Copyright © Microsoft Corporation. All rights reserved. |
License |
Version |
8.202 |
Context |
Open source implementation of the Java platform |
Purpose |
The Java platform used to execute the Logstash application |
Location |
Copyright |
Copyright © 1989, 1991 Free Software Foundation, Inc. 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA |
License |
GNU General Public License, version 2, with the Classpath Exception |
Google Sheets (VBO)
A Visual Business Object (VBO) is available for use with Blue Prism that allows interaction with Google Sheets using the Google Sheets API.
Version |
v4 |
Context |
Interaction with spreadsheets |
Purpose |
Provides automation of spreadsheets presented in Google Sheets |
Location |
Copyright |
Copyright © 2017 Google Inc. |
License |
Login Agent
The Login Agent is a separate component that logs into Windows without requiring physical user authentication. The code is heavily based on samples provided by Microsoft.
Microsoft provided examples were leveraged in the production of Login Agent and include sample code relating to interacting with the Windows Credential Provider.
Version |
N/A – Use of published code samples only |
Context |
Reference Material |
Purpose |
Reference material used in the production of Login Agent |
Location |
Separate, independently installed component (as required) |
Copyright |
License |
There is no specific license detailed in the downloaded samples / code. However, according to the Microsoft Developer Services Agreement/Software. c. Software without license terms. You may use other software we make available on the Documentation Portals without license terms solely to design, develop, and test your programs to run on Microsoft products and services; provided, that software made available through the Documentation Portals marked as "sample" or "example" and without license terms is licensed to you under the terms of the Microsoft Public License (MS-PL). |
MAPIEx
The Blue Prism MAPIEx library is based on an existing extended MAPI library, detailed below. Note that the following is transcribed from the help file distributed with the MAPIEx release. MAPIEx is a separate source base and a separate component from the Blue Prism product.
Version |
N/A - Extended MAPI Wrapper released 5th December 2009 |
Context |
Functionality Wrapper: MAPIEx |
Purpose |
Enables interaction with mailboxes via MAPIEx for sending, receiving and processing emails. |
Location |
Copyright |
Extended MAPI Wrapper By Noel Dillabough, 5 Dec 2009. |
License |
Released under the Common Development and Distribution License (CDDL-1.0) In keeping with the requirements of the license, the full source code and project files for the MAPIEx library is available upon request to Blue Prism. |
Microsoft Outlook Email (VBO)
A Visual Business Object (VBO) is available for use with Blue Prism that allows Microsoft Outlook to be easily automated.
Version |
Microsoft.Office.Interop.Outlook Version: 14.0.4760.1000 |
Context |
Functionality Wrapper: Outlook. |
Purpose |
Enables interaction with Outlook to perform Email related actions. |
Location |
Copyright |
License |
Blue Prism Trial
When using the dedicated installers to install Blue Prism on-premise trial, some additional components are provided.
Version |
Microsoft SQL Server 2017 LocalDB |
Context |
Data storage |
Purpose |
Provide a locally installed database to store Blue Prism data items |
Location |
Blue Prism Trial installer |
Copyright |
License |
Referenced licenses
Apache License
Version 2.0, January 2004
http://www.apache.org/licenses/
TERMS AND CONDITIONS FOR USE, REPRODUCTION, AND DISTRIBUTION
Definitions.
""License"" shall mean the terms and conditions for use, reproduction, and distribution as defined by Sections 1 through 9 of this document.
""Licensor"" shall mean the copyright owner or entity authorized by the copyright owner that is granting the License.
""Legal Entity"" shall mean the union of the acting entity and all other entities that control, are controlled by, or are under common control with that entity. For the purposes of this definition,
""control"" means (i) the power, direct or indirect, to cause the direction or management of such entity, whether by contract or otherwise, or (ii) ownership of fifty percent (50%) or more of the outstanding shares, or (iii) beneficial ownership of such entity.
""You"" (or ""Your"") shall mean an individual or Legal Entity exercising permissions granted by this License.
""Source"" form shall mean the preferred form for making modifications, including but not limited to software source code, documentation source, and configuration files.
""Object"" form shall mean any form resulting from mechanical transformation or translation of a Source form, including but not limited to compiled object code, generated documentation, and conversions to other media types.
""Work"" shall mean the work of authorship, whether in Source or Object form, made available under the License, as indicated by a copyright notice that is included in or attached to the work (an example is provided in the Appendix below).
""Derivative Works"" shall mean any work, whether in Source or Object form, that is based on (or derived from) the Work and for which the editorial revisions, annotations, elaborations, or other modifications represent, as a whole, an original work of authorship. For the purposes of this License, Derivative Works shall not include works that remain separable from, or merely link (or bind by name) to the interfaces of, the Work and Derivative Works thereof.
""Contribution"" shall mean any work of authorship, including the original version of the Work and any modifications or additions to that Work or Derivative Works thereof, that is intentionally submitted to Licensor for inclusion in the Work by the copyright owner or by an individual or Legal Entity authorized to submit on behalf of the copyright owner. For the purposes of this definition, ""submitted"" means any form of electronic, verbal, or written communication sent to the Licensor or its representatives, including but not limited to communication on electronic mailing lists, source code control systems, and issue tracking systems that are managed by, or on behalf of, the Licensor for the purpose of discussing and improving the Work, but excluding communication that is conspicuously marked or otherwise designated in writing by the copyright owner as ""Not a Contribution.""
""Contributor"" shall mean Licensor and any individual or Legal Entity on behalf of whom a Contribution has been received by Licensor and subsequently incorporated within the Work.
- Grant of Copyright License. Subject to the terms and conditions of this License, each Contributor hereby grants to You a perpetual, worldwide, non-exclusive, no-charge, royalty-free, irrevocable copyright license to reproduce, prepare Derivative Works of, publicly display, publicly perform, sublicense, and distribute the Work and such Derivative Works in Source or Object form.
- Grant of Patent License. Subject to the terms and conditions of this License, each Contributor hereby grants to You a perpetual, worldwide, non-exclusive, no-charge, royalty-free, irrevocable (except as stated in this section) patent license to make, have made, use, offer to sell, sell, import, and otherwise transfer the Work, where such license applies only to those patent claims licensable by such Contributor that are necessarily infringed by their Contribution(s) alone or by combination of their Contribution(s) with the Work to which such Contribution(s) was submitted. If You institute patent litigation against any entity (including a cross-claim or counterclaim in a lawsuit) alleging that the Work or a Contribution incorporated within the Work constitutes direct or contributory patent infringement, then any patent licenses granted to You under this License for that Work shall terminate as of the date such litigation is filed.
- Redistribution. You may reproduce and distribute copies of the Work or Derivative Works thereof in any medium, with or without modifications, and in Source or Object form, provided that You meet the following conditions:
- You must give any other recipients of the Work or Derivative Works a copy of this License; and
- You must cause any modified files to carry prominent notices stating that You changed the files; and
- You must retain, in the Source form of any Derivative Works that You distribute, all copyright, patent, trademark, and attribution notices from the Source form of the Work, excluding those notices that do not pertain to any part of the Derivative Works; and
If the Work includes a ""NOTICE"" text file as part of its distribution, then any Derivative Works that You distribute must include a readable copy of the attribution notices contained within such NOTICE file, excluding those notices that do not pertain to any part of the Derivative Works, in at least one of the following places: within a NOTICE text file distributed as part of the Derivative Works; within the Source form or documentation, if provided along with the Derivative Works; or, within a display generated by the Derivative Works, if and wherever such third-party notices normally appear. The contents of the NOTICE file are for informational purposes only and do not modify the License. You may add Your own attribution notices within Derivative Works that You distribute, alongside or as an addendum to the NOTICE text from the Work, provided that such additional attribution notices cannot be construed as modifying the License.
You may add Your own copyright statement to Your modifications and may provide additional or different license terms and conditions for use, reproduction, or distribution of Your modifications, or for any such Derivative Works as a whole, provided Your use, reproduction, and distribution of the Work otherwise complies with the conditions stated in this License.
- Submission of Contributions. Unless You explicitly state otherwise, any Contribution intentionally submitted for inclusion in the Work by You to the Licensor shall be under the terms and conditions of this License, without any additional terms or conditions. Notwithstanding the above, nothing herein shall supersede or modify the terms of any separate license agreement you may have executed with Licensor regarding such Contributions.
- Trademarks. This License does not grant permission to use the trade names, trademarks, service marks, or product names of the Licensor, except as required for reasonable and customary use in describing the origin of the Work and reproducing the content of the NOTICE file.
- Disclaimer of Warranty. Unless required by applicable law or agreed to in writing, Licensor provides the Work (and each Contributor provides its Contributions) on an ""AS IS"" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied, including, without limitation, any warranties or conditions of TITLE, NON-INFRINGEMENT, MERCHANTABILITY, or FITNESS FOR A PARTICULAR PURPOSE. You are solely responsible for determining the appropriateness of using or redistributing the Work and assume any risks associated with Your exercise of permissions under this License.
- Limitation of Liability. In no event and under no legal theory, whether in tort (including negligence), contract, or otherwise, unless required by applicable law (such as deliberate and grossly negligent acts) or agreed to in writing, shall any Contributor be liable to You for damages, including any direct, indirect, special, incidental, or consequential damages of any character arising as a result of this License or out of the use or inability to use the Work (including but not limited to damages for loss of goodwill, work stoppage, computer failure or malfunction, or any and all other commercial damages or losses), even if such Contributor has been advised of the possibility of such damages.
- Accepting Warranty or Additional Liability. While redistributing the Work or Derivative Works thereof, You may choose to offer, and charge a fee for, acceptance of support, warranty, indemnity, or other liability obligations and/or rights consistent with this License. However, in accepting such obligations, You may act only on Your own behalf and on Your sole responsibility, not on behalf of any other Contributor, and only if You agree to indemnify, defend, and hold each Contributor harmless for any liability incurred by, or claims asserted against, such Contributor by reason of your accepting any such warranty or additional liability.
Note: This license has also been called the "Simplified BSD License" and the "FreeBSD License". See also the
3-clause BSD License.
Copyright <YEAR> <COPYRIGHT HOLDER>
Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
1. Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer.
2. Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
BSD-3
Copyright ©. All rights reserved.
- Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer.
- Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution.
- Neither the name of the copyright holder nor the names of its contributors may be used to endorse or promote products derived from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
THE WORK (AS DEFINED BELOW) IS PROVIDED UNDER THE TERMS OF THIS CODE PROJECT OPEN LICENSE ("LICENSE"). THE WORK IS PROTECTED BY COPYRIGHT AND/OR OTHER APPLICABLE LAW. ANY USE OF THE WORK OTHER THAN AS AUTHORIZED UNDER THIS LICENSE OR COPYRIGHT LAW IS PROHIBITED.
BY EXERCISING ANY RIGHTS TO THE WORK PROVIDED HEREIN, YOU ACCEPT AND AGREE TO BE BOUND BY THE TERMS OF THIS LICENSE. THE AUTHOR GRANTS YOU THE RIGHTS CONTAINED HEREIN IN CONSIDERATION OF YOUR ACCEPTANCE OF SUCH TERMS AND CONDITIONS. IF YOU DO NOT AGREE TO ACCEPT AND BE BOUND BY THE TERMS OF THIS LICENSE, YOU CANNOT MAKE ANY USE OF THE WORK.
- Definitions.
- "Articles" means, collectively, all articles written by Author which describes how the Source Code and Executable Files for the Work may be used by a user.
- "Author" means the individual or entity that offers the Work under the terms of this License.
- "Derivative Work" means a work based upon the Work or upon the Work and other pre-existing works.
- "Executable Files" refer to the executables, binary files, configuration and any required data files included in the Work.
- "Publisher" means the provider of the website, magazine, CD-ROM, DVD or other medium from or by which the Work is obtained by You.
- "Source Code" refers to the collection of source code and configuration files used to create the Executable Files.
- "Standard Version" refers to such a Work if it has not been modified, or has been modified in accordance with the consent of the Author, such consent being in the full discretion of the Author.
- "Work" refers to the collection of files distributed by the Publisher, including the Source Code, Executable Files, binaries, data files, documentation, whitepapers and the Articles.
- "You" is you, an individual or entity wishing to use the Work and exercise your rights under this License.
- Fair Use/Fair Use Rights. Nothing in this License is intended to reduce, limit, or restrict any rights arising from fair use, fair dealing, first sale or other limitations on the exclusive rights of the copyright owner under copyright law or other applicable laws.
- License Grant. Subject to the terms and conditions of this License, the Author hereby grants You a worldwide, royalty-free, non-exclusive, perpetual (for the duration of the applicable copyright) license to exercise the rights in the Work as stated below:
- You may use the standard version of the Source Code or Executable Files in Your own applications.
- You may apply bug fixes, portability fixes and other modifications obtained from the Public Domain or from the Author. A Work modified in such a way shall still be considered the standard version and will be subject to this License.
- You may otherwise modify Your copy of this Work (excluding the Articles) in any way to create a Derivative Work, provided that You insert a prominent notice in each changed file stating how, when and where You changed that file.
- You may distribute the standard version of the Executable Files and Source Code or Derivative Work in aggregate with other (possibly commercial) programs as part of a larger (possibly commercial) software distribution.
The Articles discussing the Work published in any form by the author may not be distributed or republished without the Author's consent. The author retains copyright to any such Articles. You may use the Executable Files and Source Code pursuant to this License but you may not repost or republish or otherwise distribute or make available the Articles, without the prior written consent of the Author.
Any subroutines or modules supplied by You and linked into the Source Code or Executable Files of this Work shall not be considered part of this Work and will not be subject to the terms of this License.
- Patent License. Subject to the terms and conditions of this License, each Author hereby grants to You a perpetual, worldwide, non-exclusive, no-charge, royalty-free, irrevocable (except as stated in this section) patent license to make, have made, use, import, and otherwise transfer the Work.
- Restrictions. The license granted in Section 3 above is expressly made subject to and limited by the following restrictions:
- You agree not to remove any of the original copyright, patent, trademark, and attribution notices and associated disclaimers that may appear in the Source Code or Executable Files.
- You agree not to advertise or in any way imply that this Work is a product of Your own.
- The name of the Author may not be used to endorse or promote products derived from the Work without the prior written consent of the Author.
- You agree not to sell, lease, or rent any part of the Work. This does not restrict you from including the Work or any part of the Work inside a larger software distribution that itself is being sold. The Work by itself, though, cannot be sold, leased or rented.
- You may distribute the Executable Files and Source Code only under the terms of this License, and You must include a copy of, or the Uniform Resource Identifier for, this License with every copy of the Executable Files or Source Code You distribute and ensure that anyone receiving such Executable Files and Source Code agrees that the terms of this License apply to such Executable Files and/or Source Code. You may not offer or impose any terms on the Work that alter or restrict the terms of this License or the recipients' exercise of the rights granted hereunder. You may not sublicense the Work. You must keep intact all notices that refer to this License and to the disclaimer of warranties. You may not distribute the Executable Files or Source Code with any technological measures that control access or use of the Work in a manner inconsistent with the terms of this License.
- You agree not to use the Work for illegal, immoral or improper purposes, or on pages containing illegal, immoral or improper material. The Work is subject to applicable export laws. You agree to comply with all such laws and regulations that may apply to the Work after Your receipt of the Work.
- Representations, Warranties and Disclaimer. THIS WORK IS PROVIDED "AS IS", "WHERE IS" AND "AS AVAILABLE", WITHOUT ANY EXPRESS OR IMPLIED WARRANTIES OR CONDITIONS OR GUARANTEES. YOU, THE USER, ASSUME ALL RISK IN ITS USE, INCLUDING COPYRIGHT INFRINGEMENT, PATENT INFRINGEMENT, SUITABILITY, ETC. AUTHOR EXPRESSLY DISCLAIMS ALL EXPRESS, IMPLIED OR STATUTORY WARRANTIES OR CONDITIONS, INCLUDING WITHOUT LIMITATION, WARRANTIES OR CONDITIONS OF MERCHANTABILITY, MERCHANTABLE QUALITY OR FITNESS FOR A PARTICULAR PURPOSE, OR ANY WARRANTY OF TITLE OR NON-INFRINGEMENT, OR THAT THE WORK (OR ANY PORTION THEREOF) IS CORRECT, USEFUL, BUG-FREE OR FREE OF VIRUSES. YOU MUST PASS THIS DISCLAIMER ON WHENEVER YOU DISTRIBUTE THE WORK OR DERIVATIVE WORKS.
- Indemnity. You agree to defend, indemnify and hold harmless the Author and the Publisher from and against any claims, suits, losses, damages, liabilities, costs, and expenses (including reasonable legal or attorneys' fees) resulting from or relating to any use of the Work by You.
- Limitation on Liability. EXCEPT TO THE EXTENT REQUIRED BY APPLICABLE LAW, IN NO EVENT WILL THE AUTHOR OR THE PUBLISHER BE LIABLE TO YOU ON ANY LEGAL THEORY FOR ANY SPECIAL, INCIDENTAL, CONSEQUENTIAL, PUNITIVE OR EXEMPLARY DAMAGES ARISING OUT OF THIS LICENSE OR THE USE OF THE WORK OR OTHERWISE, EVEN IF THE AUTHOR OR THE PUBLISHER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES.
- Termination.
- This License and the rights granted hereunder will terminate automatically upon any breach by You of any term of this License. Individuals or entities who have received Derivative Works from You under this License, however, will not have their licenses terminated provided such individuals or entities remain in full compliance with those licenses. Sections 1, 2, 6, 7, 8, 9, 10 and 11 will survive any termination of this License.
- If You bring a copyright, trademark, patent or any other infringement claim against any contributor over infringements You claim are made by the Work, your License from such contributor to the Work ends automatically.
- Subject to the above terms and conditions, this License is perpetual (for the duration of the applicable copyright in the Work). Notwithstanding the above, the Author reserves the right to release the Work under different license terms or to stop distributing the Work at any time; provided, however that any such election will not serve to withdraw this License (or any other license that has been, or is required to be, granted under the terms of this License), and this License will continue in full force and effect unless terminated as stated above.
- Publisher. The parties hereby confirm that the Publisher shall not, under any circumstances, be responsible for and shall not have any liability in respect of the subject matter of this License. The Publisher makes no warranty whatsoever in connection with the Work and shall not be liable to You or any party on any legal theory for any damages whatsoever, including without limitation any general, special, incidental or consequential damages arising in connection to this license. The Publisher reserves the right to cease making the Work available to You at any time without notice
- Miscellaneous
- This License shall be governed by the laws of the location of the head office of the Author or if the Author is an individual, the laws of location of the principal place of residence of the Author.
- If any provision of this License is invalid or unenforceable under applicable law, it shall not affect the validity or enforceability of the remainder of the terms of this License, and without further action by the parties to this License, such provision shall be reformed to the minimum extent necessary to make such provision valid and enforceable.
- No term or provision of this License shall be deemed waived and no breach consented to unless such waiver or consent shall be in writing and signed by the party to be charged with such waiver or consent.
- This License constitutes the entire agreement between the parties with respect to the Work licensed herein. There are no understandings, agreements or representations with respect to the Work not specified herein. The Author shall not be bound by any additional provisions that may appear in any communication from You. This License may not be modified without the mutual written agreement of the Author and You.
Copyright © The CefSharp Authors. All rights reserved.
Redistribution and use in source and binary forms, with or withoutmodification, are permitted provided that the following conditions are met:
- Neither the name of Google Inc. nor the name Chromium Embedded Framework nor the name CefSharp nor the names of its contributors may be used to endorse or promote products derived from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS"AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOTLIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
The GNU General Public License (GPL)
Version 2, June 1991
Copyright (C) 1989, 1991 Free Software Foundation, Inc. 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
Everyone is permitted to copy and distribute verbatim copies of this license document, but changing it is not allowed.
TERMS AND CONDITIONS FOR COPYING, DISTRIBUTION AND MODIFICATION
This License applies to any program or other work which contains a notice placed by the copyright holder saying it may be distributed under the terms of this General Public License. The "Program", below, refers to any such program or work, and a "work based on the Program" means either the Program or any derivative work under copyright law: that is to say, a work containing the Program or a portion of it, either verbatim or with modifications and/or translated into another language. (Hereinafter, translation is included without limitation in the term "modification".) Each licensee is addressed as "you".
Activities other than copying, distribution and modification are not covered by this License; they are outside its scope. The act of running the Program is not restricted, and the output from the Program is covered only if its contents constitute a work based on the Program (independent of having been made by running the Program). Whether that is true depends on what the Program does.
You may copy and distribute verbatim copies of the Program's source code as you receive it, in any medium, provided that you conspicuously and appropriately publish on each copy an appropriate copyright notice and disclaimer of warranty; keep intact all the notices that refer to this License and to the absence of any warranty; and give any other recipients of the Program a copy of this License along with the Program.
You may charge a fee for the physical act of transferring a copy, and you may at your option offer warranty protection in exchange for a fee.
- You may modify your copy or copies of the Program or any portion of it, thus forming a work based on the Program, and copy and distribute such modifications or work under the terms of Section 1 above, provided that you also meet all of these conditions:
- You must cause the modified files to carry prominent notices stating that you changed the files and the date of any change.
- You must cause any work that you distribute or publish, that in whole or in part contains or is derived from the Program or any part thereof, to be licensed as a whole at no charge to all third parties under the terms of this License.
If the modified program normally reads commands interactively when run, you must cause it, when started running for such interactive use in the most ordinary way, to print or display an announcement including an appropriate copyright notice and a notice that there is no warranty (or else, saying that you provide a warranty) and that users may redistribute the program under these conditions, and telling the user how to view a copy of this License. (Exception: if the Program itself is interactive but does not normally print such an announcement, your work based on the Program is not required to print an announcement.)
These requirements apply to the modified work as a whole. If identifiable sections of that work are not derived from the Program, and can be reasonably considered independent and separate works in themselves, then this License, and its terms, do not apply to those sections when you distribute them as separate works. But when you distribute the same sections as part of a whole which is a work based on the Program, the distribution of the whole must be on the terms of this License, whose permissions for other licensees extend to the entire whole, and thus to each and every part regardless of who wrote it.
Thus, it is not the intent of this section to claim rights or contest your rights to work written entirely by you; rather, the intent is to exercise the right to control the distribution of derivative or collective works based on the Program.
In addition, mere aggregation of another work not based on the Program with the Program (or with a work based on the Program) on a volume of a storage or distribution medium does not bring the other work under the scope of this License.
- You may copy and distribute the Program (or a work based on it, under Section 2) in object code or executable form under the terms of Sections 1 and 2 above provided that you also do one of the following:
- Accompany it with the complete corresponding machine-readable source code, which must be distributed under the terms of Sections 1 and 2 above on a medium customarily used for software interchange; or,
- Accompany it with a written offer, valid for at least three years, to give any third party, for a charge no more than your cost of physically performing source distribution, a complete machine-readable copy of the corresponding source code, to be distributed under the terms of Sections 1 and 2 above on a medium customarily used for software interchange; or,
- Accompany it with the information you received as to the offer to distribute corresponding source code. (This alternative is allowed only for noncommercial distribution and only if you received the program in object code or executable form with such an offer, in accord with Subsection b above.)
The source code for a work means the preferred form of the work for making modifications to it. For an executable work, complete source code means all the source code for all modules it contains, plus any associated interface definition files, plus the scripts used to control compilation and installation of the executable. However, as a special exception, the source code distributed need not include anything that is normally distributed (in either source or binary form) with the major components (compiler, kernel, and so on) of the operating system on which the executable runs, unless that component itself accompanies the executable.
If distribution of executable or object code is made by offering access to copy from a designated place, then offering equivalent access to copy the source code from the same place counts as distribution of the source code, even though third parties are not compelled to copy the source along with the object code.
- You may not copy, modify, sublicense, or distribute the Program except as expressly provided under this License. Any attempt otherwise to copy, modify, sublicense or distribute the Program is void, and will automatically terminateyour rights under this License. However, parties who have received copies, or rights, from you under this License will not have their licenses terminated so long as such parties remain in full compliance.
- You are not required to accept this License, since you have not signed it. However, nothing else grants you permission to modify or distribute the Program or its derivative works. These actions are prohibited by law if you do not accept this License. Therefore, by modifying or distributing the Program (or any work based on the Program), you indicate your acceptance of this License to do so, and all its terms and conditions for copying, distributing or modifying the Program or works based on it.
- Each time you redistribute the Program (or any work based on the Program), the recipient automatically receives a license from the original licensor to copy, distribute or modify the Program subject to these terms and conditions. You may not impose any further restrictions on the recipients' exercise of the rights granted herein. You are not responsible for enforcing compliance by third parties to this License.
If, as a consequence of a court judgment or allegation of patent infringement or for any other reason (not limited to patent issues), conditions are imposed on you (whether by court order, agreement or otherwise) that contradict the conditions of this License, they do not excuse you from the conditions of this License. If you cannot distribute so as to satisfy simultaneously your obligations under this License and any other pertinent obligations, then as a consequence you may not distribute the Program at all. For example, if a patent license would not permit royalty-free redistribution of the Program by all those who receive copies directly or indirectly through you, then the only way you could satisfy both it and this License would be to refrain entirely from distribution of the Program.
If any portion of this section is held invalid or unenforceable under any particular circumstance, the balance of the section is intended to apply and the section as a whole is intended to apply in other circumstances.
It is not the purpose of this section to induce you to infringe any patents or other property right claims or to contest validity of any such claims; this section has the sole purpose of protecting the integrity of the free software distribution system, which is implemented by public license practices. Many people have made generous contributions to the wide range of software distributed through that system in reliance on consistent application of that system; it is up to the author/donor to decide if he or she is willing to distribute software through any other system and a licensee cannot impose that choice.
This section is intended to make thoroughly clear what is believed to be a consequence of the rest of this License.
- If the distribution and/or use of the Program is restricted in certain countries either by patents or by copyrighted interfaces, the original copyright holder who places the Program under this License may add an explicit geographical distribution limitation excluding those countries, so that distribution is permitted only in or among countries not thus excluded. In such case, this License incorporates the limitation as if written in the body of this License.
The Free Software Foundation may publish revised and/or new versions of the General Public License from time to time. Such new versions will be similar in spirit to the present version, but may differ in detail to address new problems or concerns.
Each version is given a distinguishing version number. If the Program specifies a version number of this License which applies to it and "any later version", you have the option of following the terms and conditions either of that version or of any later version published by the Free Software Foundation. If the Program does not specify a version number of this License, you may choose any version ever published by the Free Software Foundation.
- If you wish to incorporate parts of the Program into other free programs whose distribution conditions are different, write to the author to ask for permission. For software which is copyrighted by the Free Software Foundation, write to the Free Software Foundation; we sometimes make exceptions for this. Our decision will be guided by the two goals of preserving the free status of all derivatives of our free software and of promoting the sharing and reuse of software generally.
NO WARRANTY
- BECAUSE THE PROGRAM IS LICENSED FREE OF CHARGE, THERE IS NO WARRANTY FOR THE PROGRAM, TO THE EXTENT PERMITTED BY APPLICABLE LAW. EXCEPT WHEN OTHERWISE STATED IN WRITING THE COPYRIGHT HOLDERS AND/OR OTHER PARTIES PROVIDE THE PROGRAM "AS IS" WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. THE ENTIRE RISK AS TO THE QUALITY AND PERFORMANCE OF THE PROGRAM IS WITH YOU. SHOULD THE PROGRAM PROVE DEFECTIVE, YOU ASSUME THE COST OF ALL NECESSARY SERVICING, REPAIR OR CORRECTION.
- IN NO EVENT UNLESS REQUIRED BY APPLICABLE LAW OR AGREED TO IN WRITING WILL ANY COPYRIGHT HOLDER, OR ANY OTHER PARTY WHO MAY MODIFY AND/OR REDISTRIBUTE THE PROGRAM AS PERMITTED ABOVE, BE LIABLE TO YOU FOR DAMAGES, INCLUDING ANY GENERAL, SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES ARISING OUT OF THE USE OR INABILITY TO USE THE PROGRAM (INCLUDING BUT NOT LIMITED TO LOSS OF DATA OR DATA BEING RENDERED INACCURATE OR LOSSES SUSTAINED BY YOU OR THIRD PARTIES OR A FAILURE OF THE PROGRAM TO OPERATE WITH ANY OTHER PROGRAMS), EVEN IF SUCH HOLDER OR OTHER PARTY HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES.
END OF TERMS AND CONDITIONS
How to Apply These Terms to Your New Programs
If you develop a new program, and you want it to be of the greatest possible use to the public, the best way to achieve this is to make it free software which everyone can redistribute and change under these terms.
To do so, attach the following notices to the program. It is safest to attach them to the start of each source file to most effectively convey the exclusion of warranty; and each file should have at least the "copyright" line and a pointer to where the full notice is found.
One line to give the program's name and a brief idea of what it does.
Copyright (C) <year> <name of author>
This program is free software; you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation; either version 2 of the License, or (at your option) any later version.
This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details.
You should have received a copy of the GNU General Public License along with this program; if not, write to the Free Software Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
Also add information on how to contact you by electronic and paper mail.
If the program is interactive, make it output a short notice like this when it starts in an interactive mode:
Gnomovision version 69, Copyright (C) year name of author Gnomovision comes with ABSOLUTELY NO WARRANTY; for details type 'show w'. This is free software, and you are welcome to redistribute it under certain conditions; type 'show c' for details.
The hypothetical commands 'show w' and 'show c' should show the appropriate parts of the General Public License. Of course, the commands you use may be called something other than 'show w' and 'show c'; they could even be mouse-clicks or menu items--whatever suits your program.
You should also get your employer (if you work as a programmer) or your school, if any, to sign a "copyright disclaimer" for the program, if necessary. Here is a sample; alter the names:
Yoyodyne, Inc., hereby disclaims all copyright interest in the program 'Gnomovision' (which makes passes at compilers) written by James Hacker.
signature of Ty Coon, 1 April 1989
Ty Coon, President of Vice
This General Public License does not permit incorporating your program into proprietary programs. If your program is a subroutine library, you may consider it more useful to permit linking proprietary applications with the
library. If this is what you want to do, use the GNU Library General Public License instead of this License.
"CLASSPATH" EXCEPTION TO THE GPL
Certain source files distributed by Oracle America and/or its affiliates are subject to the following clarification and special exception to the GPL, but only where Oracle has expressly included in the particular source file's header
the words "Oracle designates this particular file as subject to the "Classpath" exception as provided by Oracle in the LICENSE file that accompanied this code."
Linking this library statically or dynamically with other modules is making a combined work based on this library. Thus, the terms and conditions of the GNU General Public License cover the whole combination.
As a special exception, the copyright holders of this library give you permission to link this library with independent modules to produce an executable, regardless of the license terms of these independent modules, and to copy and distribute the resulting executable under terms of your choice, provided that you also meet, for each linked independent module, the terms and conditions of the license of that module. An independent module is a module which is not derived from or based on this library. If you modify this library, you may extend this exception to your version of the library, but you are not obligated to do so. If you do not wish to do so, delete this exception statement from your version.
Version 3, 29 June 2007
Copyright © 2007 Free Software Foundation, Inc. <https://fsf.org/>
This version of the GNU Lesser General Public License incorporates the terms and conditions of version 3 of the GNU General Public License, supplemented by the additional permissions listed below.
Additional Definitions.
As used herein, “this License” refers to version 3 of the GNU Lesser General Public License, and the “GNU GPL” refers to version 3 of the GNU General Public License.
“The Library” refers to a covered work governed by this License, other than an Application or a Combined Work as defined below.
An “Application” is any work that makes use of an interface provided by the Library, but which is not otherwise based on the Library. Defining a subclass of a class defined by the Library is deemed a mode of using an interface provided by the Library.
A “Combined Work” is a work produced by combining or linking an Application with the Library. The particular version of the Library with which the Combined Work was made is also called the “Linked Version”.
The “Minimal Corresponding Source” for a Combined Work means the Corresponding Source for the Combined Work, excluding any source code for portions of the Combined Work that, considered in isolation, are based on the Application, and not on the Linked Version.
The “Corresponding Application Code” for a Combined Work means the object code and/or source code for the Application, including any data and utility programs needed for reproducing the Combined Work from the Application, but excluding the System Libraries of the Combined Work.
Exception to Section 3 of the GNU GPL.
You may convey a covered work under sections 3 and 4 of this License without being bound by section 3 of the GNU GPL.
Conveying Modified Versions.
If you modify a copy of the Library, and, in your modifications, a facility refers to a function or data to be supplied by an Application that uses the facility (other than as an argument passed when the facility is invoked), then you may convey a copy of the modified version:
- under this License, provided that you make a good faith effort to ensure that, in the event an Application does not supply the function or data, the facility still operates, and performs whatever part of its purpose remains meaningful, or
- under the GNU GPL, with none of the additional permissions of this License applicable to that copy.
Object Code Incorporating Material from Library Header Files.
The object code form of an Application may incorporate material from a header file that is part of the Library. You may convey such object code under terms of your choice, provided that, if the incorporated material is not limited to numerical parameters, data structure layouts and accessors, or small macros, inline functions and templates (ten or fewer lines in length), you do both of the following:
- Give prominent notice with each copy of the object code that the Library is used in it and that the Library and its use are covered by this License.
- Accompany the object code with a copy of the GNU GPL and this license document.
Combined Works.
You may convey a Combined Work under terms of your choice that, taken together, effectively do not restrict modification of the portions of the Library contained in the Combined Work and reverse engineering for debugging such modifications, if you also do each of the following:
- Give prominent notice with each copy of the Combined Work that the Library is used in it and that the Library and its use are covered by this License.
- Accompany the Combined Work with a copy of the GNU GPL and this license document.
- For a Combined Work that displays copyright notices during execution, include the copyright notice for the Library among these notices, as well as a reference directing the user to the copies of the GNU GPL and this license document.
- Do one of the following:
- Convey the Minimal Corresponding Source under the terms of this License, and the Corresponding Application Code in a form suitable for, and under terms that permit, the user to recombine or relink the Application with a modified version of the Linked Version to produce a modified Combined Work, in the manner specified by section 6 of the GNU GPL for conveying Corresponding Source.
- Use a suitable shared library mechanism for linking with the Library. A suitable mechanism is one that (a) uses at run time a copy of the Library already present on the user's computer system, and (b) will operate properly with a modified version of the Library that is interface-compatible with the Linked Version.
- Provide Installation Information, but only if you would otherwise be required to provide such information under section 6 of the GNU GPL, and only to the extent that such information is necessary to install and execute a modified version of the Combined Work produced by recombining or relinking the Application with a modified version of the Linked Version. (If you use option 4d0, the Installation Information must accompany the Minimal Corresponding Source and Corresponding Application Code. If you use option 4d1, you must provide the Installation Information in the manner specified by section 6 of the GNU GPL for conveying Corresponding Source.)
Combined Libraries.
You may place library facilities that are a work based on the Library side by side in a single library together with other library facilities that are not Applications and are not covered by this License, and convey such a combined library under terms of your choice, if you do both of the following:
- Accompany the combined library with a copy of the same work based on the Library, uncombined with any other library facilities, conveyed under the terms of this License.
- Give prominent notice with the combined library that part of it is a work based on the Library, and explaining where to find the accompanying uncombined form of the same work.
Revised Versions of the GNU Lesser General Public License.
The Free Software Foundation may publish revised and/or new versions of the GNU Lesser General Public License from time to time. Such new versions will be similar in spirit to the present version, but may differ in detail to address new problems or concerns.
Each version is given a distinguishing version number. If the Library as you received it specifies that a certain numbered version of the GNU Lesser General Public License “or any later version” applies to it, you have the option of following the terms and conditions either of that published version or of any later version published by the Free Software Foundation. If the Library as you received it does not specify a version number of the GNU Lesser General Public License, you may choose any version of the GNU Lesser General Public License ever published by the Free Software Foundation.
If the Library as you received it specifies that a proxy can decide whether future versions of the GNU Lesser General Public License shall apply, that proxy's public statement of acceptance of any version is permanent authorization for you to choose that version for the Library.
BY USING THE SOFTWARE, YOU ACCEPT THESE TERMS. IF YOU DO NOT ACCEPT THEM, DO NOT USE THE SOFTWARE.
If you comply with these license terms, you have the rights below.
- INSTALLATION AND USE RIGHTS.
- Installation and Use.
- You may install and use any number of copies of the software on your devices.
- Third Party Programs. The software may include third party programs that Microsoft, not the third party, licenses to you under this agreement. Notices, if any, for the third party program are included for your information only.
- ADDITIONAL LICENSING REQUIREMENTS AND/OR USE RIGHTS.
- Distributable Code.
- Right to Use and Distribute. You are permitted to distribute the software in programs you develop if you comply with the terms below:
- You may copy and distribute the object code form of the software (“Distributable Code”) in programs you develop. You may not modify the software.
- You may permit distributors of your programs to copy and distribute the Distributable Code as part of those programs.
- Distribution Requirements. For any Distributable Code you distribute, you must
- add significant primary functionality to it in your programs;
- require distributors and external end users to agree to terms that protect it at least as much as this agreement;
- display your valid copyright notice on your programs; and
- indemnify, defend, and hold harmless Microsoft from any claims, including attorneys’ fees, related to the distribution or use of your programs.
- Distribution Restrictions. You may not
- alter any copyright, trademark or patent notice in the Distributable Code;
- use Microsoft’s trademarks in your programs’ names or in a way that suggests your programs come from or are endorsed by Microsoft;
- include Distributable Code in malicious, deceptive or unlawful programs; or
- modify or distribute the source code of any Distributable Code so that any part of it becomes subject to an Excluded License. An Excluded License is one that requires, as a condition of use, modification or distribution, that
- the code be disclosed or distributed in source code form; or
- others have the right to modify it.
- SCOPE OF LICENSE. The software is licensed, not sold. This agreement only gives you some rights to use the software. Microsoft reserves all other rights. Unless applicable law gives you more rights despite this limitation, you may use the software only as expressly permitted in this agreement. In doing so, you must comply with any technical limitations in the software that only allow you to use it in certain ways. You may not
- work around any technical limitations in the software;
- reverse engineer, decompile or disassemble the software, except and only to the extent that applicable law expressly permits, despite this limitation;
- make more copies of the software than specified in this agreement or allowed by applicable law, despite this limitation;
- publish the software for others to copy;
- rent, lease or lend the software;
- transfer the software or this agreement to any third party; or
- use the software for commercial software hosting services.
- EXPORT RESTRICTIONS. The software is subject to United States export laws and regulations. You must comply with all domestic and international export laws and regulations that apply to the software. These laws include restrictions on destinations, end users and end use. For additional information, see www.microsoft.com/exporting.
- SUPPORT SERVICES. Because this software is “as is,” we may not provide support services for it.
- ENTIRE AGREEMENT. This agreement, and the terms for supplements, updates, Internet-based services and support services that you use, are the entire agreement for the software and support services.
- APPLICABLE LAW.
- United States. If you acquired the software in the United States, Washington state law governs the interpretation of this agreement and applies to claims for breach of it, regardless of conflict of laws principles. The laws of the state where you live govern all other claims, including claims under state consumer protection laws, unfair competition laws, and in tort.
- Outside the United States. If you acquired the software in any other country, the laws of that country apply.
- LEGAL EFFECT. This agreement describes certain legal rights. You may have other rights under the laws of your country. You may also have rights with respect to the party from whom you acquired the software. This agreement does not change your rights under the laws of your country if the laws of your country do not permit it to do so.
- DISCLAIMER OF WARRANTY. THE SOFTWARE IS LICENSED “AS-IS.” YOU BEAR THE RISK OF USING IT. MICROSOFT GIVES NO EXPRESS WARRANTIES, GUARANTEES OR CONDITIONS. YOU MAY HAVE ADDITIONAL CONSUMER RIGHTS UNDER YOUR LOCAL LAWS WHICH THIS AGREEMENT CANNOT CHANGE. TO THE EXTENT PERMITTED UNDER YOUR LOCAL LAWS, MICROSOFT EXCLUDES THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
LIMITATION ON AND EXCLUSION OF REMEDIES AND DAMAGES. YOU CAN RECOVER FROM MICROSOFT AND ITS SUPPLIERS ONLY DIRECT DAMAGES UP TO U.S. $5.00. YOU CANNOT RECOVER ANY OTHER DAMAGES, INCLUDING CONSEQUENTIAL, LOST PROFITS, SPECIAL, NDIRECT OR INCIDENTAL DAMAGES.
This limitation applies to
- anything related to the software, services, content (including code) on third party Internet sites, or third party programs, and
- claims for breach of contract, breach of warranty, guarantee or condition, strict liability, negligence, or other tort to the extent permitted by applicable law.
- It also applies even if Microsoft knew or should have known about the possibility of the damages. The above limitation or exclusion may not apply to you because your country may not allow the exclusion or limitation of incidental, consequential or other damages.
This license governs use of the accompanying software. If you use the software, you accept this license. If you do not accept the license, do not use the software.
Definitions
The terms "reproduce," "reproduction," "derivative works," and "distribution" have the same meaning here as under U.S. copyright law.
A "contribution" is the original software, or any additions or changes to the software.
A "contributor" is any person that distributes its contribution under this license.
"Licensed patents" are a contributor's patent claims that read directly on its contribution.
- Grant of Rights
- Copyright Grant- Subject to the terms of this license, including the license conditions and limitations in section 3, each contributor grants you a non-exclusive, worldwide, royalty-free copyright license to reproduce its contribution, prepare derivative works of its contribution, and distribute its contribution or any derivative works that you create.
- Patent Grant- Subject to the terms of this license, including the license conditions and limitations in section 3, each contributor grants you a non-exclusive, worldwide, royalty-free license under its licensed patents to make, have made, use, sell, offer for sale, import, and/or otherwise dispose of its contribution in the software or derivative works of the contribution in the software.
- Conditions and Limitations
- No Trademark License- This license does not grant you rights to use any contributors' name, logo, or trademarks.
- If you bring a patent claim against any contributor over patents that you claim are infringed by the software, your patent license from such contributor to the software ends automatically.
- If you distribute any portion of the software, you must retain all copyright, patent, trademark, and attribution notices that are present in the software.
- If you distribute any portion of the software in source code form, you may do so only under this license by including a complete copy of this license with your distribution. If you distribute any portion of the software in compiled or object code form, you may only do so under a license that complies with this license.
- The software is licensed "as-is." You bear the risk of using it. The contributors give no express warranties, guarantees or conditions. You may have additional consumer rights under your local laws which this license cannot change. To the extent permitted under your local laws, the contributors exclude the implied warranties of merchantability, fitness for a particular purpose and non-infringement.
MICROSOFT SOFTWARE LICENSE TERMS
These license terms are an agreement between Microsoft Corporation (or based on where you live, one of its affiliates) and you. Please read them. They apply to the software named above, which includes the media on which you received it, if any. The terms also apply to any Microsoft
- updates,
- supplements,
- Internet-based services, and
- support services
for this software, unless other terms accompany those items. If so, those terms apply.
- INSTALLATION AND USE RIGHTS. You may install and use any number of copies of the software on your devices to design, develop and test your programs.
- Right to Use and Distribute. If you comply with the terms below:
- You may copy and distribute the object code form of the software ("Distributable Code") in programs you develop; and
- for any Distributable Code having a filename extension of .lib, distribute only the results of running such Distributable Code through a linker with your program;
- distribute Distributable Code included in a setup program only as part of that setup program without modification;
- indemnify, defend, and hold harmless Microsoft from any claims, including attorneys' fees, related to the distribution or use of your programs.
- use Microsoft's trademarks in your programs' names or in a way that suggests your programs come from or are endorsed by Microsoft;
- distribute Distributable Code to run on a platform other than the Windows platform;
- SCOPE OF LICENSE. The software is licensed, not sold. Unless applicable law gives you more rights, Microsoft reserves all other rights not expressly granted under this agreement, whether by implication, estoppel or otherwise. You may use the software only as expressly permitted in this agreement. In doing so, you must comply with any technical limitations in the software that only allow you to use it in certain ways. You may not
- THIRD PARTY NOTICES. The software may include third party components with separate legal notices or governed by other agreements, as may be described in the ThirdPartyNotices file accompanying the software. Even if such components are governed by other agreements, the disclaimers and the limitations on and exclusions of damages below also apply.
- BACKUP COPY. You may make one backup copy of the software. You may use it only to reinstall the software.
- DOCUMENTATION. Any person that has valid access to your computer or internal network may copy and use the documentation for your internal, reference purposes.
- SUPPORT SERVICES. Because this software is "as is," we may not provide support services for it.
- APPLICABLE LAW.
DISCLAIMER OF WARRANTY. THE SOFTWARE IS LICENSED "AS-IS." YOU BEAR THE RISK OF USING IT. MICROSOFT GIVES NO EXPRESS WARRANTIES, GUARANTEES OR CONDITIONS. YOU MAY HAVE ADDITIONAL CONSUMER RIGHTS OR STATUTORY GUARANTEES UNDER YOUR LOCAL LAWS WHICH THIS AGREEMENT CANNOT CHANGE. TO THE EXTENT PERMITTED UNDER YOUR LOCAL LAWS, MICROSOFT EXCLUDES THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
FOR AUSTRALIA - You have statutory guarantees under the Australian Consumer Law and nothing in these terms is intended to affect those rights.
LIMITATION ON AND EXCLUSION OF REMEDIES AND DAMAGES. YOU CAN RECOVER FROM MICROSOFT AND ITS SUPPLIERS ONLY DIRECT DAMAGES UP TO U.S. $5.00. YOU CANNOT RECOVER ANY OTHER DAMAGES, INCLUDING CONSEQUENTIAL, LOST PROFITS, SPECIAL, INDIRECT OR INCIDENTAL DAMAGES.
- anything related to the software, services, content (including code) on third party Internet sites, or third party programs; and
MICROSOFT SQL SERVER 2017 LOCALDB
updates,
supplements,
support services
Distributable Code.
You may copy and distribute the object code form of the software (“Distributable Code”) in programs you develop; and
APPLICABLE LAW.
DISCLAIMER OF WARRANTY. THE SOFTWARE IS LICENSED “AS-IS.” YOU BEAR THE RISK OF USING IT. MICROSOFT GIVES NO EXPRESS WARRANTIES, GUARANTEES OR CONDITIONS. YOU MAY HAVE ADDITIONAL CONSUMER RIGHTS OR STATUTORY GUARANTEES UNDER YOUR LOCAL LAWS WHICH THIS AGREEMENT CANNOT CHANGE. TO THE EXTENT PERMITTED UNDER YOUR LOCAL LAWS, MICROSOFT EXCLUDES THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
FOR AUSTRALIA - YOU HAVE STATUTORY GUARANTEES UNDER THE AUSTRALIAN CONSUMER LAW AND NOTHING IN THESE TERMS IS INTENDED TO AFFECT THOSE RIGHTS.
The MIT License (MIT)
Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions: The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
The ScintillaNET bindings are Copyright 2002-2006 by Garrett Serack <[email protected]>
All Rights Reserved
Permission to use, copy, modify, and distribute this software and its documentation for any purpose and without fee is hereby granted, provided that the above copyright notice appear in all copies and that both that copyright notice and this permission notice appear in supporting documentation.
GARRETT SERACK AND ALL EMPLOYERS PAST AND PRESENT DISCLAIM ALL WARRANTIES WITH REGARD TO THIS SOFTWARE, INCLUDING ALL IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS, IN NO EVENT SHALL GARRETT SERACK AND ALL EMPLOYERS PAST AND PRESENT BE LIABLE FOR ANY SPECIAL, INDIRECT OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
The license for Scintilla is as follows:
Copyright 1998-2006 by Neil Hodgson <[email protected]>
All Rights Reserved
NEIL HODGSON DISCLAIMS ALL WARRANTIES WITH REGARD TO THIS SOFTWARE, INCLUDING ALL IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS, IN NO EVENT SHALL NEIL HODGSON BE LIABLE FOR ANY SPECIAL, INDIRECT OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
